Show only
Search instead for
Ability to sort Levels by Height in Project Browser
Please add the ability to sort Levels by Height in the Project Browser so we dont have to add a 1. or 2. as a prefix to each level so they display logically by height in the Project Browser.
Thank you. I eventually found the "Sort By" part tucked away at the bottom of the "Grouping and Sorting" tab once I had to created another Browser Organisation name as I could not change the "all" one and then changed it to "Associated Level".
I think its too way too difficult to do this:
Its tucked away - make it more visible - like RMC on the Floor Plans area and have the sorting menus appear. Also you cannot change/Edit the "all" Browser Orginization setting - perhaps also add a Duplicate option to duplicate the "all" browser organization. And its named oddly - just name it better eg. Sort Level by Height iso Associated Level.
Floor order There are two points to the problem: 1. The "facade" is from bottom to top, while the "floor plan" is from top to bottom. When inserting a new floor in the middle of the "facade", the "floor plan" is always at the bottom. Suggestion: The order of floors in the floor plan always follows the elevation, and the order is refreshed when adding a new floor Please refer to the attached image for details ~Wishing everything all the best
