Ability to scale the viewport individually on the sheet
For larger projects, usually several part views have to be created (duplicate as dependent view), as the building is too large to fit with the 1:50 scale on an ISO A0 sheet.
However, overview plans are usually needed, where exactly the same content should be seen as on the partial plans, which are then scaled down so that the whole building fits on an A0 plan (usually half as big, so 1:100). It does not matter that the texts are not scaled correctly on this overview plan.
The only possible workaround is to create a double-sized plan frame and plan stamp, insert the overall view of the floor plan, and print the plan half the size (50% smaller). This is very time-consuming and has to be made (especially for projects with a title block specified by the client) each time.
My wish is a scaling factor on the sheet that applies only to an individual viewport on this plan. So technically some kind of "zoom" of the view (for example “scale on sheet”: 100% / 200% / 50% / ....) That factor is always set on “100%” by default when placing a view. The viewport is enlarged or reduced only on the sheet, while the view itself remains on its scale in the model.
Example:
