Show only
Search instead for
One of our EP customer ask the same question, since the lady found some information lost when she using PDF-XChange Printer 2012. So could Revit has a default PDF creator just as AutoCAD does?
This assumes you have paid for a PDF writer that supports linking, I'm suggesting Autodesk provide a PDF driver with hyperlink support. Either as a add-in, extention, part of subscription ect.
Our office has mutilpe PDF drivers I would like to just have one, just like AutoCAD.
Back in the day I used Revit 4.0, when Revit was Revit Technology Corporation. It had a built in .pdf engine (Pinebush PDF Writer), and as the software spit out .pdf drawings all the view callouts were linked, your sheet index was linked to your sheets, it was a pretty cool feature. It was just a simple check box in the print dialog box, to link drawings. As Autodesk purchased the software, the built in .pdf engine was yanked out.
Theres not many comments on the linking in of pdf's which I would find more useful than the print as there are plenty of free PDF printers that are pretty good!
@lonerganjeff 's point is very valid as you can measure within the PDF and snap to points so the info is there in the PDF.
Thanks for your submission and votes on this idea! We are evaluating where this request falls into our roadmap and will provide an update when we have made a decision. Please note that we are considering this idea to be the "Provide a built-in PDF printer" and will consider linking PDF separately.
I have had issues in the past with CutePDF not embedding fonts or displaying fonts. If the writer came from Autodesk like "RVT to PDF" output it should support fonts and hyperlinks without question.
