2D PDF printing support
Not exactly an original idea, but provide a built-in PDF printer
107 Comments
evan_grady
BlueBeam plugin can help a lot with printing in Revit. Also, it does add some nice functionality with revisions when editing pdfs and other functionality which can help as well for various applications.
nmarcelis
Even though this has now been implemented, the diroots plugin is simply the best for exporting PDFs, DWGs, etc.
wongccf
Community Visitor
Should allow adding customized paper size for export to pdf
Simon_Weel
@wongccf Option Use Sheet Size works a treat!
AdamBielanski
Community Visitor
Printing manager "like DiRoots" is a MUST. Revit is even worse than centuries-old AutoCAD. Unbeliveable!
mhiserZFHXS
@AdamBielanski
What do you mean? Revit has had native PDF export for several years now. Are you referring to something else?
Ric_Weber
@AdamBielanski, posting on an "Implemented" idea probably won't get much traction, but I believe what you're looking for is an idea similar to this one?:  https://forums.autodesk.com/t5/revit-ideas/print-pdf-and-export-dwg-sheets-from-a-linked-model/idi-p...
