2019's Tabs has changed the 'Ctrl + Tab' and 'Ctrl + Shift + Tab' shortcuts!
While I like the new tabs feature as it is useful to see at a glance the currently open tabs, it seems to have come at the expense of a very simple but time saving feature. Which is the ability to use 'Ctrl + Tab' & 'Ctrl + Shift + Tab' to go back and forth between the last opened view. By this I mean the basic functionality of this feature has changed with the new visible tabs implementation. Instead of tabbing between, say, my floor plan I just had open and a section I opened from the floor plan, it Tabs in a Linear fashion through all the currently views in the Tab. Often, and expect most users do this, I will open a view intending on quickly Tabbing back and forth between these open views to compare them. These shortcuts are now tedious to use because it requires awareness of where your view is amongst the Tabs of open views, meaning we tab multiple times to get back the view we literally just had open. Or it requires us to close all inactive views, to then be able to tab back and forth without cycling through other views.
I understand thereasoning for changing the way this tabbing operates, as it would be confusing if someone were to tab using the 'Tab + Shift' shortcut and see the selected view tabs jump all over the place.
But for me, and I expect others, this has reduced my productivity and has been a source of constant frustration ever since the implementation of the Revit 2019. I would much rather the ability to quickly Tab back to my previous open view (in order of last viewed) than have all the open views visible as tabs.
The only solution I can see to allow both the exist, is to have the tabs organised based on the order of previously viewed. Meaning every time a view is opened, whether it already be in the open view tabs or not, it is moved to the front of the list.
The original functionality of the 'Shift + Tab' shortcuts needs to be restored asap, as this is a backwards step in productivity of the software.
132 Comments
Mark_Engwirda
Is it just too simple to just have a forward & back arrow to toggle through your views just like a web browser does?
Everyone already understands that system!
I agree - please open up for the the old abillity. This really **** up my workflow...
Andersorum
Agree - please change it back! I never watch and click the "open view" tabs.
weaverUBYCS
Reinventing the wheel by making it more square-like does not help anyone. You have invented functionality that does not help anyone but instead hurts those who used previous functionality to great effect. Your UX/UI folks should be reprimanded.
In terms of rankings we are currently on page 6. Upvote!
TimGrissom
It helped me.  I find the tabbed views much more useful than the old ctrl+tab functionality ever was.  I hate working in the old versions of Revit that do not have the tabs, it's like being blindfolded.
I am sure a lot of people were really upset when digitizers went away too but our professions have still managed to survive.
6775052186_d4a5f49d1b_b
"The illiterate of the 21st century are not those who cannot read and write, but those who cannot learn, unlearn, and relearn." - Alvin Toffler
Think the point here is that they could have kept the ctrl-tab and introduced tabs. No need to remove functionality.
weaverUBYCS
Cool. You must have missed the part where you get to keep your tabs. Nobody is asking to remove tabs. The explicit insult is also appreciated, and I think you know where it belongs.
TimGrissom
Collins and Cooper, I agree, if we can have both, that is the best option, but I am not sure that it is possible.  With tabs grouped into tiled windows or scattered across multiple monitors, is it possible to keep both functionalities completely intact?  I hope so, but if we can only have one, my vote is for the tabs.
What have they done now? Broken something that worked fine, taken up extra screen space in doing it and Reducing productivity. So frustrating! Can't we have an option to turn this off and get our screen space and functionality back?
steveperkio
I use Ctrl+Tab a lot too especially to compare views.
The major issue is that Ctrl+Tab will stop working if you attempt to go past either the first or last tab and Revit stops responding to your input of Ctrl+Tab.
I've noticed that if your cursor is located directly over an editable element, then it works as expected and you can keep cycling through views.
The loss of focus needs to be addressed.
Perk
jhague
Observer
As a keyboard shortcut user, in cad and revit, this removal has slowed me right down.
Please patch ASAP.
jhague
Observer
Another thing, When I've used the tabs at top, I've accidentally closed an open project, thinking it's just a view tab when I've had 2 projects open to compare/ or multi task.
Dangerous and adds holes to the cheese.
Please get rid of tabs completely or give us an option.
You can click & drag the tabs and reorder them any way you'd like. This will essentially retain the functionality you're chasing from previous versions.
Mark_Engwirda
Thanks for your help Daniel, don't know about your solution but in any
case, if I try to rearrange any tabs or re-dock any tabs Revit abruptly
crashes 🙂
ncostall
Seems there is still no original ctrl+tab functionality in the 2021 version. Having an option in the preferences to either ctrl+tab in the order the tabs are displayed (new version) or in the order that they were last used (old version) seems like a simple addition to make to a Revit update and would help so many users used to the old version and increase productivity again.
harlan_brumm
Status changed to: Accepted
We are pleased to say that we have accepted this idea and added it to our public roadmap - https://blogs.autodesk.com/revit/2020/04/20/revit-public-roadmap-update-april-2020/
Thanks!
-The Factory
Harris_Josh
@harlan_brumm This is incredible news!!
Thank you for listening to us!
DavidwAAI
Thank You!
Yes! Thank you so much!
