Bandwidth Requirements
Message 1 of 9
The IT department is asking about the minmum bandwidth requirement for A360 upload and interaction with C4R.
Is there any Autodesk stated minimums or defined numbers.
I have seen this URL (it is very general) - http://knowledge.autodesk.com/support/a360/learn-explore/caas/CloudHelp/cloudhelp/ENU/123112/files/a...
David
Replies (8)
Message 2 of 9
KyleB_Autodesk
There isn't really a minimum bandwidth pwer se, C4R will work with what you've got.  That said, you want users to be able to ramp to at least 5 Mbps symmetrical for burst transfers.  Above that will result in faster completion of the Data I/O portions of Revit operations.
-Kyle
Kyle Bernhardt
Director
Building Design Strategy
Autodesk, Inc.
Message 3 of 9
Thanks.
Message 4 of 9
tech3design
Hi Kyle, I know you can help me with this. What are the minimum bandwidth requirements for AutoCAD 3D, Civil 3D, Map 3D, Revit? for 200 users. or What is a good rule of thumb? Storing the files on a Server, LAN and access them with local workstation.
Thank you,
Message 5 of 9
tech3design
Thank you,
Message 6 of 9
sureshchotrani
Minimum 512 KBPS
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Message 7 of 9
tech3design
Are you refering to having a large revit model being opened from a server?
Thank you,
Message 8 of 9
tech3design
how many installed of revit can you put on a server? to remove in for 18 users? without having it install locally?
Thank you,
Message 9 of 9
It would be useful if this reply could be extend to a per-user figure; In an office environment, what is the upper limit of concurrent users all editing models hosted in C4R that can be comfortably accommodated by 5Mbps burst capacity? 5 users, 10 users and office of 100 users? Thanks
