if you are using Glue, then the models are still stored on Autodesk Servers for collaboration. If you are working with Revit worksharing in general, the Local Models are typically stored on the local user's workstations. If they have lots of Revit models they work on simultaneously, then a larger hard drive may be needed.
Each Revit model you make will determine the total size of the file and the total hard drive space needed depends on how many revit models total your end user's work on.
If for example, I have an end user who has 15 Revit projects to work on at any point in time during the year, each model could potentially be 1GB in size which is a sizeable model to work with. That means the workstation needs at least 15GB of space to store that data. If you take into account OS, programs, etc as well as Revit content, a 250GB drive should be fine. Most hard drives in workstations start at 500GB now so again you should be fine.
Lastly, you could just buy a NAS network drive that has say 10-20TB of storage space and route all Local Revit Models to that location so the size of the local workstation hard drive would be irrelevant in regards to Revit model storage.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn | Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
