Windows Sill Height and Head Height show"-nan"
8 REPLIES 8
Message 1 of 9
manhgt214
563 Views, 8 Replies
Help!
Can you explain to me...
I maked Wall  by Model In Place =>insert windows or door to wall but when I change value of Windows Sill Height and Head Height show"-nan"?
Height of Wall relative with sill height?
Thanks in advance
Labels (1)
8 REPLIES 8
Message 2 of 9
ennujozlagam
in reply to: manhgt214
i did replicate what you did, but didn't see or show -nan value. try to change numbers value and see if helps. thanks
check attached file sample R2020 version.
Message 3 of 9
manhgt214
in reply to: ennujozlagam
Mr !
I open file of you, if I change Value of Sill Height=<990 this error will show same the picture.
Message 4 of 9
manhgt214
Video Attached, please see below
Message 5 of 9
syman2000
Do you have plugin installed or different language keyboard?
Message 6 of 9
manhgt214
in reply to: syman2000
I using language English and Jappanese, addin JOTool and Bim One.
Message 7 of 9
manhgt214
I was remove Japanese language and all addin but dont solved
Message 8 of 9
syman2000
Repair Revit and see now if that helps fix the issue. Sometimes plugin may cause it to go haywire.
Message 9 of 9
manhgt214
I was Repair Software and try again but same before.
Please see this file atached, wall draw by original no issue, seem like only wall draw by Model in place...
Forma Design Contest
