Keyboard Shortcut for Point Element
5 ANTWORTEN 5
Nachricht 1 von 6
642 Aufrufe, 5 Antworten
I've been doing a lot of work in adaptive modeling, and a lot of the work is based on reference points and I'm getting tired of finding the button every time I need it. I checked the Shortcuts Window, but couldn't even find the command to add a shortcut. Any ideas?
I've attached a screenshot with the expanded command details for reference.
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: Anonymous
Please do not post same question in multiple forums.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
als Antwort auf: L.Maas
Really, @L.Maas? I wasn't aware of that rule. I've been guilty of doing that in the past.
Nachricht 4 von 6
L.Maas
als Antwort auf: barthbradley
@barthbradley It is a quite common forums rule. See THIS post on the community forum.
Louis
Nachricht 5 von 6
Corsten.Au
its annoying not to have a shortcut / or not able to give a shortcut to that command..
till then...try this..
1. After placing one point, you can use " Ctrl " " Drag " ( this will create a copy.)
2. while creating family no one uses that icon to recreate the point..
3. And in the project, for families etc, " CS " create similar is popular..
4. unfortunately "CS' doesn't work for " point Element "
Cheers
Corsten
Building Designer
Nachricht 6 von 6
This lack feature in set the keyboard shortcut annoy me too. I cannot find the keyboard shortcut for place Point Element. IMO, Revit not good as Inventor in view of keyboard shortcut. In Inventor, I can set all commands by keyboard shortcut. No need for the mouse. Very flexible. Life is easier in Inventor than Revit.
