Windows Sill Height and Head Height show"-nan"
8 REPLIES 8
Message 1 of 9
manhgt214
596 Views, 8 Replies
Help!
Can you explain to me...
I maked Wall  by Model In Place =>insert windows or door to wall but when I change value of Windows Sill Height and Head Height show"-nan"?
Height of Wall relative with sill height?
Thanks in advance
Labels (1)
8 REPLIES 8
Message 2 of 9
ennujozlagam
in reply to: manhgt214
i did replicate what you did, but didn't see or show -nan value. try to change numbers value and see if helps. thanks
check attached file sample R2020 version.
Message 3 of 9
manhgt214
in reply to: ennujozlagam
Mr !
I open file of you, if I change Value of Sill Height=<990 this error will show same the picture.
Message 4 of 9
manhgt214
Video Attached, please see below
Message 5 of 9
syman2000
Do you have plugin installed or different language keyboard?
Message 6 of 9
manhgt214
in reply to: syman2000
I using language English and Jappanese, addin JOTool and Bim One.
Message 7 of 9
manhgt214
I was remove Japanese language and all addin but dont solved
Message 8 of 9
syman2000
Repair Revit and see now if that helps fix the issue. Sometimes plugin may cause it to go haywire.
Message 9 of 9
manhgt214
I was Repair Software and try again but same before.
Please see this file atached, wall draw by original no issue, seem like only wall draw by Model in place...
