window grilles not showing up
I edited an andersen window family, in order to get the right amount of grilles I needed (fixed divided) and I made the grilles as an extrusion and then locked them into place with reference lines.
I have checked the visibility but as soon as i change the view from hidden line to shaded or consistent color, they disappear!
Is there anything else I could try?
I've attached the file for refrence
ennujozlagam
@Anonymous hello, i don't see any problem with your window family. please see attached. thanks
@ennujozlagam Hi, I think the 3D view is the only place they show up.. i had trouble seeing then in elevation.
Thanks!
ennujozlagam
@Anonymous hello, i dont have any problem with elevation view stiil can see. please see attached. thanks
@Anonymous
Try this revised family.  You have a masking regions covering the mullion.  Aside from that, there are a bunch of elevation masking regions and detail lines that are not quite matching the geometry properly.  I have removed them and set the actual window to show on elevations since it is clean enough.
@ToanDN this is perfect, thank you so much! I did not even think of looking for masking regions.
@ennujozlagam @ToanDN thanks for your all you help!
