Revit won't let me print PDF
4 ANTWORTEN 4
Nachricht 1 von 5
1808 Aufrufe, 4 Antworten
 Hi, I'm having a problem with both Revit Architecture 2016 and 2017: I can't print PDFs, when I open the print window, I can't select any option for Print Range, Options, File, etc. I also can't open the Settings. I'm using the Microsoft Print to PDF printer. Sometimes when using PrimoPDF the problem would fix itself but only for a while, and then it happened again. This happens in every file I open, so I'm supposing it's a problem with the program or the printer drivers in my computer.
I'll upload a screenshot of the print window so you can see the problem
Thanks in advance,
Tags (3)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, i'm using Bullzip pdf and PDF995 and don't encounter any problem. try to use another printer driver and install latest updates form autodesk and see if helps. thanks
Nachricht 3 von 5
Do not use Microsoft PDF printer. Go to Windows printers folder and choose another one as default printer.
Nachricht 4 von 5
Archigrafix_Norge
Revit has several bugs with virtual printers. We have managed to print with all sheets sizes with Microsoft PDF printer, but its not user friendly process. It includes several modifications.
Have a look in the Revit App store and you will find superior solutions to print to PDF. Including printing landscape and portrait, and all sheet sizes in the same print job, optimized for architectural offices. If you want some specific guidance please let us know we have developed such tools.
Luis Santos
archi systems as
Nachricht 5 von 5
WFTDesign
als Antwort auf: Archigrafix_Norge
Revit App Store?  Does that apply to Revit LT?
