Error exporting Revit to DWG file
Message 1 of 19
Hi, I´m having a problem exporting sheets to dwg file (only with one file), when I export them, the dwg file is empty, a 10k size, could you help me with this issue please.  Thanks.
Benjamin
Replies (18)
Message 2 of 19
ennujozlagam
@Anonymous hello, try to audit your revit file before exporting to autocad or post your file so we can check. thanks
Message 3 of 19
Thank you ennujozlagam, here is my file.
Message 4 of 19
I exported the file you send With different export settings Couldnt find any problem, also attached one file exported with Loma export setup
Message 5 of 19
ennujozlagam
@Anonymous hello,no issues exporting to autocad file, just set/modify your dwg export. please see attached. thanks
Message 6 of 19
Hello
I am having an issue exporting Dwg's and I use the export option
I followed some steps from Autodesk, i.e:
I cleaned up the TEMP folder, deleted all the detached files and folders, cleaned the recycle bin, then created a new local, audited the file but the issue persists.
1. When I restart the program it exports once and does not allow anymore exports,
2. When exporting a set of drawings it may export just a few of them and the rest will get an error message as seen in the image.
2. when i try to export and I don't get the error message it creates files that are 0KB, in this instance it does not show the message at the bottom right corner saying exporting.
i will appreciate any assistance
Message 7 of 19
We are having the same problem in our drawings. How can we fix it Autodesk?? Than you in advance
Message 8 of 19
After multiple audits done to the file. I can export DWG’s again
I audited the Central model and discarded the local copies and detached
New local copies from the Audited file. I did this a couple times and one
day it exported just fine.
Message 9 of 19
We have the same problem.
We are working in BIM360 with Revit 2019.
First DWG exportation is ok, then Revit save a 0 kB dwg files.
This only happens when exporting views with MEP systems. If we export views that contain only architectural elements, everything works perfectly.
Does anyone know if it's a known problem?
Giulio
Message 10 of 19
I'm having the exact same issue. I think i'll be able to export all the dwg's required if i did them all individually, however 50+ drawings which are regularly being amended, this is very time consuming and costly.
I've attached the error report.
Error message
Elements
The following views could not be published. Sheet: A101 - SITE PLAN : id 2073349
I've never had this issue before. Nothing drastically has been amended to the REVIT model.
Message 11 of 19
I don't believe this is solved, i think there is more of an issue. See my post below.
Message 12 of 19
HI ALL
i am also facing the same issues , i think its only for Revit 2019
adarsh
Message 13 of 19
We also started having this issue in our Office. I would recommend moving this Question to a new thread, cause it differs from the original one which is already marked as solved.
Greetings, Omar
Message 14 of 19
bạn có thể chỉ cho tôi fix lỗi xuất từ revit sang cad được không? thank bạn
Message 15 of 19
Hi All,
 I am  facing same issue. pleas see below snap.
Message 16 of 19
Has this issue been addressed yet?
Regards
Message 17 of 19
I too have encountered exactly the same issue.  If I open the Revit project with Audit, I can then export one or two views before the exports stop working.  The CAD files are 0kb and the files can't then be deleted as an error message insists that "this file is open in Revit".
This issue isn't new, so could Autodesk please advise on a solution?
Regards
Message 18 of 19
ChrisNeedhamNZ
I've just run into this problem also.
Very frustrating! Managed to export the three most important sheets in a set, then gave up on the rest.
Not good enough Autodesk!
Chris Needham
Whangarei
New Zealand
Message 19 of 19
I'm also facing the same issue, how you solved your revit problem when converting files to CAD Files.
