Why no polyline in Revit 'Draw' panel?
2 REPLIES 2
mmany
2670 Views, 2 Replies
Before the Revit purists come back with 'Revit is not AutoCAD' - A rectangle is a polyline, a hexagon is a polyline, and Autodesk has seen fit to include these shapes in the Draw Panel.
If I'm creating a component in place, say a cabinet door, and it's elevation is an L shape (or any custom shape - this is for a wall of cabinetry with odd-shaped panels), why, under 'Edit Extrusion', do I have to draw each custom shaped extrusion profile with these goofy single lines?  The command doesn't even continue in a sensible way.
I'm learning slowly, but this sort of thing is driving me crazy.  Is there a faster way to draw shapes?
2 REPLIES 2
constantin.stroescu
in reply to: mmany
have you activated Chain? Activating Chain it will work as a polyline..
Constantin Stroescu
mmany
in reply to: constantin.stroescu
OMG, Thank you very much for that.  You have made my day.  Learning this on my own it's been a long and painfully slow process, this will speed things up.
Forma Design Contest
Technology Administrators
