Hello
I'm having a problem I can't solve today. I need to dimension between the face of a wall and non parallel wall opposite it. The non parallel wall turns a 90 degree corner, and it is at this corner that I want to measure perpendicular to my first wall.
1. Is there a way to dimension between non-parallel walls? When you place the dimension you click on the wall at the location you want to dimension, so I don't see why Revit can't place the dimension at that point. That dimension would be particular to that one point along the non-parallel wall...
2. I got around this by placing a reference plane and dimensioning to that, but I'd rather not do this because then if I hide the reference plane, my dimension disappears.
Is there another work around or am I missing a tool I don't know about?
Many thanks
