when exporting to ifc single components such as floors are split into into multiple components with duplicated ids
2 REPLIES 2
alvaro.martinezWDU3Z
278 Views, 2 Replies
when exporting to ifc, single objects such as floors are split into into multiple components with duplicated ids, being these the original revit object's. see the example in the pics attached. In revit I only have on floor objects with one id, but in ifc, it has been split into multiple pieces, each with the same id (as per the original revit file)
Is there a way to prevent this from happening by selecting/unselecting IFC export options in a particular way?
Labels (2)
2 REPLIES 2
I do not think so. In IFC They appear as several separate meshes and therefore show up as separate elements. Because they originate from single object they will have same Revit ID (but still different IFC GUID).
What you can do is create separate floors in Revit.
Louis
Please mention Revit version, especially when uploading Revit files.
thanks for your quick response!
Thought so too. hoped there would be a solution without having to 'touch' the original revit file, but doesn,t seem to be the case.
Forma Design Contest
Technology Administrators
