what parameter do you use to adjust the vertical position of a roof
3 REPLIES 3
dposey
450 Views, 3 Replies
3 REPLIES 3
in reply to: dposey
level.
chrisplyler
in reply to: dposey
To be clear, "level" is not a parameter.
Every roof is associated with one of your Levels. So you can change the elevation of a roof simply by changing the elevation of the Level it is associated with.
in reply to: chrisplyler
Hi Chris, If you highlight the roof and go to its properties, there is a parameter called "Base offset from level" . Try that.
Forma Design Contest
