what parameter do you use to adjust the vertical position of a roof
To be clear, "level" is not a parameter.
Every roof is associated with one of your Levels. So you can change the elevation of a roof simply by changing the elevation of the Level it is associated with.
Hi Chris, If you highlight the roof and go to its properties, there is a parameter called "Base offset from level" . Try that.
