walls,columns and finish layer problem
12 REPLIES 12
Message 1 of 13
Shay.Gaghe
601 Views, 12 Replies
Shay.Gaghe
hi
i have a wall with a finish layer both sides.
i saw that the finish layers know to covers columns as well,
the weird thing is that in 1 level it looks good while in another level it looks like the wall can't see the columns.
https://drive.google.com/file/d/1M6-7_rdbdWds1CI7o8ip3HWIh9lbbTQr/view?usp=sharing
any idea?
file is attached
S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
hi
any idea?
file is attached
S
12 REPLIES 12
Message 2 of 13
in reply to: Shay.Gaghe
The only weird thing I see is the Wall Wrap at the end of the Walls meeting the Column.
....maybe a better approach would be to make the wall continuous and not start and stop wall segments at the Columns.
Message 3 of 13
Shay.Gaghe
in reply to: barthbradley
Shay.Gaghe
That’s what I tried to say
Message 4 of 13
Use Join geometry to join walls and columns.  By the way, why do you choose RTE and not RVT format for your project?
Message 5 of 13
Shay.Gaghe
in reply to: ToanDN
Shay.Gaghe
hi
i don't understand the join idea.
The columns and walls made of different materials,
if everything needs to be joined, what is the use of join? Why it doesn't  do it automatically?
Shay
hi
Shay
Message 6 of 13
@Shay.Gaghe wrote:
hi
Shay
Only few things can join automatically (wall to wall, wall to architectural column). Walls do not join automatically to structural columns so if you need to do it manually.
@Shay.Gaghe wrote:
hi
Shay
Message 7 of 13
Shay.Gaghe
Shay.Gaghe
hi
continue with those columns display,
in the roof plane i don't want to see the column outline,
i tried hiding columns category but it doesn't work,
how can i achieve this?
Shay
hi
Shay
Message 8 of 13
Draw the walls continously overlapping the structural columns. Make the columns shorter than the walls. Join walls and columns.
Message 9 of 13
Shay.Gaghe
in reply to: ToanDN
Shay.Gaghe
not sure i understand.
the walls and columns are joined
Message 10 of 13
But are the columns shorter than the walls?
Message 11 of 13
Shay.Gaghe
in reply to: ToanDN
Shay.Gaghe
the columns is 20 , and the wall is 2+ 20 + 2
Message 12 of 13
Those are the widths.  You need to make the column height < the wall height, and set the roof plan's Cut Plane to be above the top of the walls.
Message 13 of 13
Shay.Gaghe
in reply to: ToanDN
Shay.Gaghe
You are right. Never though of the obtuse
Shay
Shay
