hi
i have a wall with a finish layer both sides.
i saw that the finish layers know to covers columns as well,
the weird thing is that in 1 level it looks good while in another level it looks like the wall can't see the columns.
https://drive.google.com/file/d/1M6-7_rdbdWds1CI7o8ip3HWIh9lbbTQr/view?usp=sharing
any idea?
file is attached
S
hi
any idea?
file is attached
S
Solved by ToanDN. Go to Solution.
The only weird thing I see is the Wall Wrap at the end of the Walls meeting the Column.
....maybe a better approach would be to make the wall continuous and not start and stop wall segments at the Columns.
Use Join geometry to join walls and columns. By the way, why do you choose RTE and not RVT format for your project?
hi
i don't understand the join idea.
The columns and walls made of different materials,
if everything needs to be joined, what is the use of join? Why it doesn't do it automatically?
Shay
hi
Shay
@Shay.Gaghe wrote:
hi
Shay
Only few things can join automatically (wall to wall, wall to architectural column). Walls do not join automatically to structural columns so if you need to do it manually.
@Shay.Gaghe wrote:
hi
Shay
hi
continue with those columns display,
in the roof plane i don't want to see the column outline,
i tried hiding columns category but it doesn't work,
how can i achieve this?
Shay
hi
Shay
Draw the walls continously overlapping the structural columns. Make the columns shorter than the walls. Join walls and columns.
But are the columns shorter than the walls?
@Shay.Gaghe wrote:
the columns is 20 , and the wall is 2+ 20 + 2
Those are the widths. You need to make the column height < the wall height, and set the roof plan's Cut Plane to be above the top of the walls.
