To explain the confusing title, I have created a door opening family, that simultaneously cuts the floor construction according to the needs of the projects. The problem is that the void that creates the opening in the door continues for another 1,5m in each direction and cuts through the floor construction. It doesn't cut the wall opposite of the door, because that is a different element out of which the family is not cut. So if I have (in this case a bathroom pod) that is less than 1,5m wide from door to wall, it creates a cut in the floor.
The wall opening within the family cannot be in any way constrained to the wall (essentially it is constrained because it is face based on the wall face...) My thinking is that a wall opening in Revit is within the family as default set up to 1,5m on each side, to ensure it could be used on virtually any wall thickness (overkill). If that is correct, is there a way to decrease this?
Here is a screencast to show the effect:
Solved by barthbradley. Go to Solution.
It is not letting me insert the screencast on the original posting for some reason, so trying here:
So, if I'm reading you right, your Door Family is a Face-Based Family and uses a Void Extrusion (in lieu of an Opening Cut) to cut the opening in the Host. If so, you can easily make the Void Depth Parametric so that you can control its Depth in the Project based on the Host thickness. Extrusion Depth Instance Parameter Value = Host Wall Thickness.
...BTW: Are you able to delete the Host in the Family? Sounds like a conversion from a Wall-Hosted Family. If so, the Host "wall" is unnecessary geometry and can probably be deleted. I would just delete it in this case.
The wall opening within the family cannot be in any way constrained to the wall (essentially it is constrained because it is face based on the wall face...) My thinking is that a wall opening in Revit is within the family as default set up to 1,5m on each side, to ensure it could be used on virtually any wall thickness (overkill). If that is correct, is there a way to decrease this?I have neverheard orexperienced this.
Can you share your model?
It is a wall based family, so the opening is actually not done by a void but by wall opening. I can't delete the host in the family, because it is a wall based family, hence the wall is the host.
I am attaching the family.
@simon.jerabek wrote:...It doesn't cut the wall opposite of the door, because that is a different element out of which the family is not cut. So if I have (in this case a bathroom pod) that is less than 1,5m wide from door to wall, it creates a cut in the floor. [RD] If Cut Geometry is used, a wall opening can/may also cut the opposite wall which is neither the host element nor joined to the original wall hosting the door/opening
The wall opening within the family cannot be in any way constrained to the wall (essentially it is constrained because it is face based on the wall face...) My thinking is that a wall opening in Revit is within the family as default set up to 1,5m on each side [RD] not really. there is no default settings for the wall opening Depth.
- The wall opening will cut the host wall (and any other Wall joined to it) regardless of the wall thickness
The family you attached consists of
None of what is in that family correlates to what you have shown in the video clip you posted ... Apart from that
How does it not correlate?
My problem is not the voids nor opposite wall being cut. It is the floor construction that is being cut by the wall opening. The opposite wall is also an independent element..
The voids are not cutting anything in the family, but have purpose of cutting the floor construction in the project - just not 1,5 out of the host.
Using a badly modeled family out of the original context may or may not recreate the demonstrated issue/error...Please read again what I wrote with regard to the issues found in the family you posted:
Using the Family you posted in a blank project behaves as expected with respect to how it has been modeled...Should you want to know what exactly is happening in your model, post the model itself (ie: Family + Project Context)
PS: The remark in red (previous reply) was not intended to imply that you are having problems cutting opposite wall but to clarify that the opposite elements may be cut by voids/opening cut of an insert hosted in a different non-related element.
- Stating something is badly modeled without knowing the purpose of it is a bit premature. The family does what it needs to and has been used on many projects already, the rare instance of having an opposite wall so close happened for the first time now, so I was just curious why that happens.
- This family is never intended to be used in a blank project, it is tailored to our models.
Anyway, I think we can close this thread. I know I can solve it with constraining a void instead of using the wall opening, I just found it interesting that this happens. Thanks for your input.
Premature? I actually believe that I have overrated it by calling it badly modeled.
Download the family you uploaded and check it out again!! You must be either using a different family or you have never modeled a family in Revit before. (Watch the GIF below...that is what you uploaded)
With all due respect, the family you attached and the the justifications provided in your reply sound more like its your first time using Revit..
- The voids are constrained where needed to be constrained and controlled by instance parameters where flexibility is necessary.
You state confidently "Constrained where needed" then you depict yourself and state that the solution is to constrain the voids...Does that tell you anything at all??
I admit it is not the prettiest family, but due to the complexity of the build up our production facility works with, it is necessary. And believe it or not, it works perfectly fine, where we are able to control the height/depth of the recess, cutout of door tiles for door frame, or whether it has a recess at all - all those things vary from project to project
Here you can see the construction of the floor, which has an elevated egde under the walls that goes above the top level of the floor tiles:
I hope it clarifies at least a little bit my reasoning behind my amateur family...
