Hello everyone,
You can see the attached walkthrough video hereby. Does anyone know why is looking like this? I am working on it days now, but I can't find a general solution.
Solved by Viveka_CD. Go to Solution.
looks like your computer may not be able to handle exporting the walkthru with highest settings...
check graphics card type/driver
try adjusting walkthru settings to not highest, but one or two levels down
send revit file to me so i can test on my system
dta@reproproducts.com
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi @Anonymous
Thanks for sharing your walkthrough video with us.
To check:
Recommendations to try:
I would be happy to take a look if you would like to post a sample file for troubleshooting. I can share a private folder if you'd like.
Thank you and we look forward to your reply update.
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
For quality production I highly recommend using the last method suggested by @Viveka_CD, generating an image sequence rather than direct-to-video; however I'd suggest using a high-quality image format such as PNG or TIFF as JPG is "lossy". This work process gives you more choices during editing, such as cutting out parts, switching them around, adding pauses, switching back and forth to other image sequences, and so on. It also frees you to use whatever container and CODEC you want e.g. MPEG-4 with H.264 encoding provided it's supported by the video editor.
Please help, whenever I exported a walkthrough, it ended up looking like this.
it splits my screen into 4, then in the middle of the video, it is going back to it's original/normal form. It's kinda frustrating for it takes me hours to export this, just to find out it's not working properly.
Thank you.
