Void Family (Hollow Floor Slab)
6 REPLIES 6
3793 Views, 6 Replies
We are trying to create a Hollow Core Slab using a nested void Family. However, the voids do not interact with the floor slab.
Os there a Problem with using a slab or Surface template? We do not have a "void template", if there is such a thing. Or is the Problem somewhere else?
6 REPLIES 6
artejon
Use a nested face-based void family.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Face-based family cutting the hosting solid, and with Cut with Voids when Loaded enabled.
in reply to: ToanDN
Thank you, it works. Now we would like to have various different void types (e.g. square, rectangle, circle etc.) which are controlled by a type Option through visibility or some other function / Parameter. Any solution for this Problem?
artejon
Make different void families as generic models, nest them into a host family and here create a family type parameter : generic models, place one of nested families to cut a geometry of a host family,
assign a label to that nested void family, create types in a host family and assign a proper nested family as a value, loaad into a project , changing a type of a family will change shape of cut.
Hi there.
Probably, you haven't told the void to cut the other mass. If you send your file, I can help you.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
dleipert
You could make a mass of floors and void cut them, then turn the floor into the hollowcore family.  Here's a video I made on void cut floors made from massing elements, enjoy!
Forma Design Contest
Technology Administrators
