Visibility of Wall Detail Level
4 REPLIES 4
BigPicture045
1213 Views, 4 Replies
Description: I would like to display a wall that has multiple structures as one solid wall structure. I create a brick drop with concrete walls and this makes the wall appear with a line through the middle of it. I want the separate structures so I can create the brick drop, but I do not want that structural line showing.
Known Work-around: Individually remove lines with invisible line tool.
Is there a manual override that can be applied to this specific wall?
In the image below I show the wall on the left with the line running through it representing the two structural parts of the wall. On the right, I show the wall as I'd like it to appear.
4 REPLIES 4
Honestly, I'm not getting it. The lines through the middle of walls on the left are coming from what?
Maybe, posting the file would be best.
This is for a crawl space plan.
The walls on this plan are using concrete block walls. I need to create a brick sill on these walls so that the brick has a place to sit. See the section how the wall comes down and sits on top of the crawl space wall.
This makes the crawl space walls have a line going through the middle of them (showing 2 separate structures so that the brick drop can be made). See the highlighted walls in the layout image. I do not want this line in the wall.
The none highlighted walls have been changed using the invisible line tool. They are the way I am going after.
My question is, is the invisible line tool the only known way to change the way a wall looks? Can I change the detail level of specific walls?
You can use/place a Plan Region.  It's all about View Range; right?
