- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Description: I would like to display a wall that has multiple structures as one solid wall structure. I create a brick drop with concrete walls and this makes the wall appear with a line through the middle of it. I want the separate structures so I can create the brick drop, but I do not want that structural line showing.
Known Work-around: Individually remove lines with invisible line tool.
Is there a manual override that can be applied to this specific wall?
In the image below I show the wall on the left with the line running through it representing the two structural parts of the wall. On the right, I show the wall as I'd like it to appear.
