Visibility of Wall Detail Level
BigPicture045
BigPicture045
Description: I would like to display a wall that has multiple structures as one solid wall structure. I create a brick drop with concrete walls and this makes the wall appear with a line through the middle of it. I want the separate structures so I can create the brick drop, but I do not want that structural line showing.
Known Work-around: Individually remove lines with invisible line tool.
Is there a manual override that can be applied to this specific wall?
In the image below I show the wall on the left with the line running through it representing the two structural parts of the wall. On the right, I show the wall as I'd like it to appear.
Honestly, I'm not getting it. The lines through the middle of walls on the left are coming from what?
Maybe, posting the file would be best.
BigPicture045
This is for a crawl space plan.
The walls on this plan are using concrete block walls. I need to create a brick sill on these walls so that the brick has a place to sit. See the section how the wall comes down and sits on top of the crawl space wall.
This makes the crawl space walls have a line going through the middle of them (showing 2 separate structures so that the brick drop can be made). See the highlighted walls in the layout image. I do not want this line in the wall.
The none highlighted walls have been changed using the invisible line tool. They are the way I am going after.
My question is, is the invisible line tool the only known way to change the way a wall looks? Can I change the detail level of specific walls?
You can use/place a Plan Region.  It's all about View Range; right?
