Material maps goes where?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
saf-a
538 Aufrufe, 2 Antworten
Hello
I'm trying to use a texture with multiple maps
but the naming is different in different sites and engines and I'm not sure where each map goes.
Can the texture in this link be created accuratly in Revit? (it has all the maps)
https://www.textures.com/download/3dscans0623/138403
This is my trial
If it is possible to  can someone please explain how?
Thank you
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: saf-a
You will need the newer Revit versions (2019?) for this that support PBR materials.
Non-PBR materials in Revit have a small yellow triangle with exclamation mark in the preview icon
.So make sure you use a PBR material
HERE a page which describes how to make these PBR materials and where to place (some) of the maps
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
als Antwort auf: L.Maas
Excellent resource @L.Maas! Thanks for sharing.
