Visibility issue for linked Revit file
2 REPLIES 2
shehab_fekry
207 Views, 2 Replies
we have architecture walls from a linked file and structural columns from another linked file
in normal case we can split walls around the column but in linked file case we know that we can't edit walls without opening Revit link file, so is there any way to edit the Visibility to hide the wall in the area of intersection between the two elements
2 REPLIES 2
jvpantin2
in reply to: shehab_fekry
You can't hide them because technically it is an interference and must be solved where appropriate.
The only way to fake "hide" walls is to blacken the columns.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
hmunsell
you can try this.... might be more trouble than its worth depending on how many you have.
  • Copy Monitor the Column, and walls if needed, from the links.
  • Once there Copy Monitored, tab select the items in the link that were copy monitored and Hide in View.
Howard Munsell
