Can anyone help me figure out why in the screenshot below some wall edges/faces are showing red or grey or even brown - they are all the identical wall type and all external facing. The same with some of the roofs - how can I set roof edges to be something other than grey and why is one of the flat roofs of the dormers randomly red top surface and a red edge?
I'm drawing up structural SIPs package so I don't want to set any of the layers to wrap.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
In your wall settings is the Wrapping at Ends set?
Howard Munsell
They are set to "none" which is how I have to have them as I'm drawing the SIP walls which consist of 11mm OSB | 150mm EPS | 11mm OSB and the OSB does not wrap at the ends - as I'm working on structural production drawings I can't use wrapping for the "look" as it will cause my framing plugin to not work when framing the SIPs
This is the solution! Thanks - I'm working off the architect's original model and they must have applied some paint settings! (Did not know about the paint function before!)
