view template makes walls seem semi transparent
9 REPLIES 9
Message 1 of 10
steve
973 Views, 9 Replies
I can't for the life of me find the parameter that makes this happen.    2 stock templates:  one makes the walls show thru interior architectural model elements - does anyone know what parameter this is???
https://drive.google.com/a/designbuildllc.com/file/d/1gHwi1DXWx8uYtesH2eFutO8GIPrkXfer/view?usp=driv...
9 REPLIES 9
Message 2 of 10
hmunsell
in reply to: steve
  • edit the View template
  • V/G Override Model
    • make sure the checkbox on the far right is checked...
  • scroll down to Walls
  • override the transparency column
Howard Munsell
Message 3 of 10
martijn_pater
in reply to: steve
It could be in the view template, see above to find that. But if it's not the settings, from time to time a view get's a little buggy... Then the issue might resolve itself if you recreate the elevation.
Message 4 of 10
steve
in reply to: hmunsell
Tried that, everything is zero transparncy.   I tried turning off transparency across the whole Walls line.
Message 5 of 10
in reply to: steve
Sound like one only element's graphic display is being affected.  Select the transparent element, right-click and check for any VG overrides by element.
By chance, do you have any filters activated in that view template?
...you sure it's a transparency and not a material such as Glass?
Message 6 of 10
in reply to: steve
Turn off Import Categories for the faulty view template.
Message 7 of 10
steve
in reply to: ToanDN
I gave up and copied a template the works and just adjusted scale.   Mystery.
Message 8 of 10
in reply to: steve
There would be no mystery if you could share the file instead of the images.
Message 9 of 10
steve
in reply to: ToanDN
Is there a way to send privately.?   We don't want to post an entire project.
Message 10 of 10
in reply to: steve
You could copy the element and the view template into a blank project and post that.
