I can't for the life of me find the parameter that makes this happen. 2 stock templates: one makes the walls show thru interior architectural model elements - does anyone know what parameter this is???
Howard Munsell
It could be in the view template, see above to find that. But if it's not the settings, from time to time a view get's a little buggy... Then the issue might resolve itself if you recreate the elevation.
Sound like one only element's graphic display is being affected. Select the transparent element, right-click and check for any VG overrides by element.
By chance, do you have any filters activated in that view template?
...you sure it's a transparency and not a material such as Glass?
