Hi there,
I have a ceiling with a featured bulkhead hanging from it that needs to be demolished in a new phase.
When I demolish the bulkhead and apply the phase filter 'Show Previous + New', a ghost rectangle is still showing in the ceiling where the wall used to be, even though it has no split faces or paint or lines or anything. The ceiling is all at the same level, and it is has the same boundary.
What am I missing?
Below a screenshot of the RCP with the ghost line in the ceiling after demolition, and applying filter 'Show previous + New'.
I know is not major, but I hate fudging. Thanks
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
that is showing the limit of demolition and the new infill
try using the show complete Phase filter
Most likely the line you see is the border between the Old Ceiling and the New Infill based on the phasing filters override but it could also be of other reasons
Show Previous + New filter
The order for that border line not to show in Previous + New filter:
A. Either - Change/Remove Phase Filter and/or PF Overrides
B. OR - All Ceiling elements are same Phase
EDIT: someone might also suggest that you use linework ![]()
