View Depth - Unlimited (Grey out Elements)
6 REPLIES 6
Jackie_Balasubramanian-BGL
246 Views, 6 Replies
Hi All,
Can you please help me with this.
In one of my old files and when I changed the view depth - Unlimited as shown in snapshot. All the element below the associated level greys out which is nice to see (which is want I wanted)
But when I do try the same step in my project file, the element below is not greyed out - it still stays black like below
I have checked every setting(filter, override graphic). Can I know where I am doing wrong and how can I grey out element just by changing the View depth to Unlimited
6 REPLIES 6
Look into Beyond line style.
Toan Nguyen
@ToanDN
Thanks for your reply. Let me check and come back on this
The grayed-out elements have nothing to do with Unlimited. Those grayed-out elements are likely the Underlay.
@Jackie_Balasubramanian-BGL wrote:
@ToanDN
Thanks for your reply, but can you please explain me elaborately if you dont mind.
All elements between the View range's Bottom and the View Depth are shown using <Beyond> line style.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
Toan Nguyen
@ToanDN , Thanks for solving this
@barthbradley  Thanks for your reply but @ToanDN reply worked perfectly.
Forma Design Contest
Technology Administrators
