Hi All,
Can you please help me with this.
In one of my old files and when I changed the view depth - Unlimited as shown in snapshot. All the element below the associated level greys out which is nice to see (which is want I wanted)
But when I do try the same step in my project file, the element below is not greyed out - it still stays black like below
I have checked every setting(filter, override graphic). Can I know where I am doing wrong and how can I grey out element just by changing the View depth to Unlimited
Solved by ToanDN. Go to Solution.
The grayed-out elements have nothing to do with Unlimited. Those grayed-out elements are likely the Underlay.
@Jackie_Balasubramanian-BGL wrote:
@ToanDN
Thanks for your reply, but can you please explain me elaborately if you dont mind.
All elements between the View range's Bottom and the View Depth are shown using <Beyond> line style.
