I know checking for errors help. but is there any other tips or solutions i can try. I mostly work with autocad so i'm kind of a new to revit .
if anyone have any ideas or settings i can change for revit that will be great. i know for autocad i turn off acceleration and RUN PURGE AND AUDIT and sometimes the overkill command does revit have something similar?
Solved by Viveka_CD. Go to Solution.
Solved by DarrenP. Go to Solution.
don't know what you mean by slow but this gives a few tips on improving Revit Performance
DarrenP
Here is an article which touches on a lot of reasons for slow performance in Revit. There are some steps to try such as disabling add-ins that you can try.
For graphics cards, please reference the certified list for cards that have been tested with Revit.
Can you share a journal file to investigate further on what may be causing this slowdown? Let me know if you have any questions, thanks!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
