There is a known issue regarding Dependent Views, which can cause the problem you are experiencing.
I do not know of a fix for Revit 2017; not sure if it has been fixed on newer versions? ( I doubt it.)
Our solution has been to NOT use Dependent Views.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
