Upgrading Drawing from Revit 2015 to Revit 2018
8 REPLIES 8
Message 1 of 9
johnsonhem
1439 Views, 8 Replies
Hello All!
When upgrading a Revit 2015 model to Revit 2018, the upgrade freezes and crashes between 64%-77% with the error message:
"An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
Solutions fried:
- Recreated User Profile
- Repaired Revit 2018
- Upgraded to the latest Revit 2018.1
- Restarted
Still, my end-user gets this issue. Please see screenshot as well.
8 REPLIES 8
Message 2 of 9
Sahay_R
in reply to: johnsonhem
Upgrade one version at a time - first 2015-2016, then 2016-2017, finally 2017-2018.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 9
in reply to: Sahay_R
I read it a little differently...I think I understand that the error is in upgrading a RVT file from 2015 to 2018. Should work all by itself. You might try opening it and auditing it at the same time.
Message 4 of 9
johnsonhem
in reply to: barthbradley
The end-user has tried detaching the model, auditing, and upgrading from local file version Revit 2015 and it still crashes in 2018. I will look into upgrading the file version by version, which is very tedious. This process should be a lot more seamless.
Message 5 of 9
aclose
hi, i have the same problem.... upgrading from 18 to revit 19...what other suggestions do you have?
Message 6 of 9
in reply to: aclose
Must you upgrade the project?
Message 7 of 9
in reply to: aclose
Do you by chance have Links in that Project from previous versions? This has been my Achilles heal before when upgrading a project . The upgrade changes to a linked model are temporary; they are not saved when you save the host model. To permanently upgrade a linked model, you must close the host model and then open, upgrade, and save the linked model.
...I know; you're gonna say "I don't want to upgrade the link".  So, unload it and then save the project.
Message 8 of 9
aclose
in reply to: ToanDN
yes, i have to upgrade...is actually my revit 18 template. with all my typical details etc.
Message 9 of 9
aclose
my file does not have any links. Man Sad
