Upgrading Drawing from Revit 2015 to Revit 2018
johnsonhem
johnsonhem
Hello All!
When upgrading a Revit 2015 model to Revit 2018, the upgrade freezes and crashes between 64%-77% with the error message:
"An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
Solutions fried:
- Recreated User Profile
- Repaired Revit 2018
- Upgraded to the latest Revit 2018.1
- Restarted
Still, my end-user gets this issue. Please see screenshot as well.
Replies (8)
Sahay_R
Upgrade one version at a time - first 2015-2016, then 2016-2017, finally 2017-2018.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
I read it a little differently...I think I understand that the error is in upgrading a RVT file from 2015 to 2018. Should work all by itself. You might try opening it and auditing it at the same time.
johnsonhem
The end-user has tried detaching the model, auditing, and upgrading from local file version Revit 2015 and it still crashes in 2018. I will look into upgrading the file version by version, which is very tedious. This process should be a lot more seamless.
aclose
hi, i have the same problem.... upgrading from 18 to revit 19...what other suggestions do you have?
Must you upgrade the project?
Do you by chance have Links in that Project from previous versions? This has been my Achilles heal before when upgrading a project . The upgrade changes to a linked model are temporary; they are not saved when you save the host model. To permanently upgrade a linked model, you must close the host model and then open, upgrade, and save the linked model.
...I know; you're gonna say "I don't want to upgrade the link".  So, unload it and then save the project.
aclose
yes, i have to upgrade...is actually my revit 18 template. with all my typical details etc.
aclose
my file does not have any links. Man Sad
