Unit
2 REPLIES 2
jegP7L8D
193 Views, 2 Replies
Unit
Would like to share this with Revit Developer. Hoping to have an option to tag the "UNITS" in the overall plan by not using the room tags. Let's say, have 10 units in one level plan. Unit A1, A2......A10, currently Revit won't allow us to tag this unit in general tagging. The only option is to name the Units in textnote which is not ideal. Another option currently available is to disable the room bounding of the walls to tag as one whole unit using room tag which is not a good option also since we would like to maintain the individual room tags in enlarged plans of each units.
Hopefully, the next version will give us an option to tag the units and maintain the room bounding of walls. and at the same times unit tag can calculate the perimeter area of the Unit.
Thank you.
Best Regars,
Jeg
2 REPLIES 2
ennujozlagam
in reply to: jegP7L8D
how about this and see if helps? thanks
jegP7L8D
Thank you so much for this. It helps.
Hoping in the next version of revit they will create a separate features just for the Unit tagging for better representation in revit.
once agin. ty so much.
Forma Design Contest
