Can you please suggest us how can we change the schedule that is representing row wise in the Format 1 to column wise in Format 2 shown in the snap attached.
Thanks & Regards
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Misunderstood what you meant by Format...From what you are saying now, it sounds like you want to transpose rows and columns which at present Revit does not offer a direct way of doing it.
It is Possible to do what you want using either of the following methods
There is an Idea posted on the following link in case you feel interested in giving it a vote
https://forums.autodesk.com/t5/revit-ideas/vertical-schedule-orientation/idi-p/7040737
