IFC import from Archicad to revit
2 ANTWORTEN 2
Nachricht 1 von 3
daniel.kinden
375 Aufrufe, 2 Antworten
Hi!
I would really like to be able to show doors/windows in imported IFC-file created from Archicad. Right now, in floor plan view it looks something like this:
However, when I drag the model, the doors appear under these blocks. Any suggestions?
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
philsogood
als Antwort auf: daniel.kinden
hi
did you find any solution?
working on a small project and same issue from the IFC import
too many objects are "generic elements" to be able to use the file properly!! :verwirrtes_Gesicht:
Phil
Nachricht 3 von 3
ennujozlagam
https://forums.autodesk.com/t5/revit-mep-forum/linked-ifc-doors-not-visible-in-every-floor/td-p/9815...
