Hi everyone,
I am trying to create a family whose types drive types of a nested family, but somehow the geometry of the nested family does not change, when choosing another type of the host family, see here:
1M = 63x63mm:
1,5M = 90x63mm:
The nested family keeps its geometry and parameters, even though the host family parameter is set to change it.
I have done this successfully before, so I am really puzzled what I have done wrong. Can a fresh pair of eyes take a look at this?
Solved by ToanDN. Go to Solution.
Edit the nested family and change all parameters controlling Geometry from Instance to Type.
I tested your family and it looks like that on screen. Is this representation not correct ?
I don't see an issue with any of the 9 types.
I can see how one could accidently change the Shared Nested Family ( "EL. Technical frame FUGA (1-1,5-2M) - LK" ) instead of the Parent Family ("Electrical Socket Frame") in the Project.
Associate the label to the nested family. It is currently <None>. See revised family.
Oh yes, that was the problem. Works as intended now, thanks for your help!
