Revit 2022 - Print scale not 100% accurate
Ian_H
Message 1 of 12
Ian_H
We noticed today that our drawings seemed off, so I set out to look into it and we had the 'fit to page' selected instead of setting zoom to 100%. That was an easy fix.
In performing these tests though, it looks like having zoom to 100% still doesn't produce a completely accurate print. I know 1/32" margin of error is very tiny, but I would assume that even at that level if I draw a line at 10', when I measure it at 1/2" scale it should be 10'.
I exported and printed a pdf and got slightly off dimension in both directions.
Any thoughts?  in the image the left tab is File->Print, the middle tab is Export->PDF, the right tab is PyRevit-> printTest prints at zoom 100.jpg
Replies (11)
Message 2 of 12
RobDraw
What is the precision of units and dimensions in Revit?
Rob
Message 3 of 12
Revit printing 24x36 (arch D) not 100% is a known issue, you can google search and there is a topic on this very forum.  Other sizes shouldn't have this problems.  Sorry.
Here is a workaround:
- create a PDF custom paper size 24.1x36.1
- print 24x36 sheets to PDF using this custom size @ 100%, center
- it is mostly okay viewing the PDF without cropping, if you need to print the PDF then choose specific %, not fit to page
See attached.
Message 4 of 12
RobDraw
@ToanDN wrote:
Revit printing 24x36 (arch D) not 100% is a known issue.
Reference?
Rob
Message 5 of 12
What do the Elements' Properties say about those elements' lengths in Revit?
Message 6 of 12
Ian_H
@RobDraw
Units are set to rounding to nearest 1/32"
@barthbradley
I have developed a habit of typing in all my distances. So the lines in the view are 10', 5', and 2.5'.
Message 7 of 12
Ian_H
@ToanDN
Thank you for the clarification and proposed solution.
It is interesting that, maybe the most common paper size,  is the one that seems have this issue.
Message 8 of 12
Is this a hard copy print? If it were me, I'd have the plotter recalibrated.  I too have never heard about the aforementioned "Arch D" issue.  Maybe it was a thing years ago.  Dunno.
Message 9 of 12
Ian_H
@barthbradley
This is a printed PDF and measured in bluebeam
Message 10 of 12
@Ian_H wrote:
@barthbradley
HUH?  This is about measuring in Bluebeam?
Ever occur to you that maybe the measurement tool ain't working, or that your expectations are too high?
Message 11 of 12
Ian_H
I don't think that Bluebeam is broken.
I did have a conversation with others on my team that at the end of the day a difference of 3/32" on a drawing that they technically aren't supposed to using to measure from in the field doesn't ultimately make a difference. Thus I would image we would proceed as we have been. I am simply chasing down answers to something that my boss noticed while reviewing in Bluebeam and wanted to know more about.
Message 12 of 12
luisPDAN6
Print with the Docuflow plugin: there is a  7 day free trial on the Revit app store. It is a metric tool so you can eventually get it more precise. It will handle your sheets in inches as well.
