I created a wall in my revit project a while ago, but then i could not delete it and i cant even select it, it does not light up when i go over it,
i see it in all my views and in the 3D view as well but i cant do anything with it.
Please see attached screenshot where the entire plan is selected except the wall in the center
Solved by TripleM-Dev.net. Go to Solution.
It that a Window-Selection or is it selecting everything at once automatically? Is it a group?
its not a group, and i did it by selecting everything at once,
but it does not matter which way i do it it never comes up
I was able to delete every wall in the Project. Maybe Audit your File.
Sorry but i still see the wall (with an opening by the end) there next to the table and chairs
Thank you so much!
i dont recall making a design option there but i guess i did.
Thanks again!
