Toposurface!
I have problem on my Toposurface, it shows below grade and I don't know how to solve this problem.
I Also have been tried eliminate some lines on my elevations without success.
Could someone help me to solve these problems.
Much Appreciated,
George
Solved by jorgedacunha60. Go to Solution.
Solved by syman2000. Go to Solution.
Solved by ToanDN. Go to Solution.
Solved by alan_eu. Go to Solution.
Probably your problem ll be easy to solve:
1. Did you try to join them? ( Menu modify / join / select that elements)
2. Try to align them. Go in 3D mode and zoom it. use AL command, click in the 1st wall, them the 2nd;
3. Maybe that's a video card bu. Try to disable on options/hardware/use hardware acceleration and restart your revit.
