Toposurface and Lines on Elevation
4 REPLIES 4
jorgedacunha60
496 Views, 4 Replies
Toposurface!
I have problem on my Toposurface, it shows below grade and I don't know how to solve this problem.
I Also have been tried eliminate some lines on my elevations without success.
Could someone help me to solve these problems.
Much Appreciated,
George
4 REPLIES 4
alan_eu
in reply to: jorgedacunha60
Hi @jorgedacunha60
Probably your problem ll be easy to solve:
1. Did you try to join them? ( Menu modify / join / select that elements)
2. Try to align them. Go in 3D mode and zoom it. use AL command, click in the 1st wall, them the 2nd;
3. Maybe that's a video card bu. Try to disable on options/hardware/use hardware acceleration and restart your revit.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
turn on section box and stretch it inward to cut the topo.
syman2000
Looks like your topo is very close to the building. You may want to extend out topo beyond building. Afterward follow what @ToanDN said with the scopebox.
jorgedacunha60
in reply to: syman2000
Happy New Year! Thank you for your input. If I check in the section box,
afterward I have to hide in view in order to render the image, because if I
uncheck the section box, I would have the same problem! I am going to try
your post and I will try to render it.
George
