toposolid error in revit 2024
9 REPLIES 9
Message 1 of 10
raumpunktmp
1724 Views, 9 Replies
it is not possible to delete points in a toposolid.
9 REPLIES 9
Message 2 of 10
in reply to: raumpunktmp
Interior points? No issues here.  Are you in Modify mode?
Border Points? Edit Sketch.
Message 3 of 10
raumpunktmp
in reply to: barthbradley
if i select an interior point i can only change its height and move it, but i cannot delete the point.
Message 4 of 10
pedruccioli
I don't know what may be going on for you, but all ok around here.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
Message 5 of 10
Are you using the DELETE key?
Message 6 of 10
raumpunktmp
yes delete key.
Message 7 of 10
Modify sub-elements, select point(s) and delete.
Toan Nguyen
Message 8 of 10
raumpunktmp
was a problem with the (mac) keyboard. it works if i press function+delete key.
Message 9 of 10
lorena_dantas
I don't have the toolbar to editing the toposolid. It disappeared.
Message 10 of 10
lorena_dantas
I got a toposolid error and then the modify toposolid toolbar disappeared. TOPOSOLID.PNG
Forma Design Contest
Technology Administrators
