Revit 2020 - Keynote schedule issue
4 ANTWORTEN 4
Nachricht 1 von 5
keith_hansell
344 Aufrufe, 4 Antworten
Hello - We have a running list of user keynotes that are separated by two types: Demolition Keynotes, and Remodel Keynotes.
I would like these to populate into the same schedule, with the demolition keynotes appearing first and the remodel keynotes appearing after the entire demolition list.
The demolition keynotes are alphanumeric and start with a "D".   D1, D2, D3, etc.
the remodel keynotes are numeric: 1, 2, 3, 4, etc.
Is there a way to accomplish this in Revit 2020? If we let the schedule run as normal, the numberic (remodel) keynotes appear before the demolition (opposite of what I want). Thanks in advance!
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: keith_hansell
can't you get there by sorting/grouping ascending/descending?
Nachricht 3 von 5
Lachlan-JWP
Is there a reason you can't use two schedules?
Nachricht 4 von 5
keith_hansell
als Antwort auf: Lachlan-JWP
Yes, this ended up being what I did...just thought there may be a more simple solution.
Nachricht 5 von 5
keith_hansell
als Antwort auf: barthbradley
This didn't work. If I reverse sorted, the numbers would be descending order.
