it is not possible to delete points in a toposolid.
Solved by raumpunktmp. Go to Solution.
Interior points? No issues here. Are you in Modify mode?
Border Points? Edit Sketch.
if i select an interior point i can only change its height and move it, but i cannot delete the point.
Modify sub-elements, select point(s) and delete.
Toan Nguyen
was a problem with the (mac) keyboard. it works if i press function+delete key.
I got a toposolid error and then the modify toposolid toolbar disappeared.
