TOOLBAR does not strech
3 REPLIES 3
328 Views, 3 Replies
We work on a double-monitor setup!
Is there a limit for how much you can strech a toolbar.
I keep all my toolbars on a dedicated screen, from the bottom of the screen to the top but they stop streching at about 1035pixels.
The screen has 1680px vertical. As you can see on the SCREEN-SHOT bellow there is a loot of space to strech them but they wont go beyond those 1035px.
WHY?
3 REPLIES 3
alan.quinn
I just tested by adding a second monitor and it seems to work for me. I'm guessing its you setting but I have no way of knowing. See the attached images for details.
Thanks for posting.
in reply to: alan.quinn
It does not work if you put Revit in one screen and all the tools in the second screen. Which is how I normally use it! 😕
Maybe its a 2012 problem as I dont remember having this issue before.
alan.quinn
Yesterday I was testing on a 17" monitor (old one). Today I flipped my Dell ST2410 on its end and I found the limitation of expanding the browser and properties boxes. Apparently this is a hard coded limitation that development set on them. I'm afraid I cannot do anythign to change this.
If you like I’d suggest leaving feedback at the below link. Information gathered is used to improve the application.
Product Contact Link:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you,
Forma Design Contest
Technology Administrators
